Power steering again
- Replies 13
- Views 3.7k
Dieselfuture 4 posts
wil440 4 posts
Mopar1973Man 2 posts
dripley 2 posts
If you want a little more easy steer, take the plunger inside the pr valve & grind the end that narrows down to where it gets straight with the rest of the plunger, about 1/8". This gives you more
Yes the small side hole got blocked while drilling through the centre
Mine oe still works after almost 20 years. I am afraid to touch it.
I fitted a new PS pump last year around August If I remember correctly, always seemed a little underpowered at idle but I thought it was down to my tyres.
Yesterday I delivered a mower I'd sold to a guy 40 odd miles away using a 12ft trailer, anyway missed the house so had to do a U turn at a T junction, it was a bit tight and to be fair I held the steering on full lock for too long and too hard, all of a sudden steering and brake pedal are both hard, I got straightened up checked for leaks , no leaks but steering hard at idle, delivered the mower and drove home with no steering or brakes at low revs.
Took the pressure pipe off and the fitting to get to the relief valve and the relief valve is stuck right in and won't come out, after fishing with a strong magnet I had to remove the PS pump
Once on the bench I managed to get the valve out, cleaned everything up with brake cleaner and everything is ok and moving as it should, polished the valve with very fine wet and dry to be sure
Did the power steering pump mod before refitting it and wow what a difference it's like a totally different truck.
In the article below it mentions about being careful not to block the small hole when drilling the centre of the fitting, this is a good tip as mine did block and I did have to redrill it
