Turbo Clocking Angles
Does anyone have good knowledge of what the turbo angles should be?  As best as I could estimate on my truck with the current turbo installed (due to rust, certain components will be destroyed upon removal - and I don't have a spare vehicle right now) it seems:
  1. the exhaust manifold mounting flange is 48 degrees (measured from horizontal).  EDIT:  May be closer to 50 degrees based on my truck, after removing turbo for better measurement.
  2. The compressor outlet is "around" 20 degrees from horizontal.  EDIT:  I'd say I would up more around 25 degrees or a little steeper to keep everything very well aligned and no stress on the rubber boot.
I would like to change the turbo back this weekend, and really want to get my turbo clocked correctly this evening so I have just one less thing to worry about after taking a Sawzall/smoke wrench to certain parts of my truck.  I have failed so far at getting that compressor snap ring back in, so once it gets back in I don't want to have to make corrections!
Any help appreciated!  I don't have the right tool to measure that compressor discharge flange angle.  I removed the boot/elbow one evening this week to measure the angle, but then discovered I haven't the right tool to do so.  @dripley this may interest you once I get the data.  Hopefully we can further refine the path blazed by @Blueox01 so BenzeForce can just offer these turbos already setup for our application.
Edited by LorenS
tag Dripley, etc.
  • Replies 43
  • Views 10.4k
  • I would like to thank @Joe_Poolfor the info on toold. Picked up the Lang and it looks very suited to the job,
  • Here are 2 tools that work quite nicely:   Lang 87 (USA made) and ATD 4031M (Taiwan, but well made)   In the pictures the blue handled one is the ATD.  I prefer the Lang, but they
  • A buddy came over this afternoon so I got the new turbo on and my new Diamond Eye 4" exhaust installed. I did NOT do anything for the waste gate, it's just wired shut right now. My HY-35 gate has
In the pictures the blue handled one is the ATD.  I prefer the Lang, but they both will remove and install an HX35 snap ring(HX35 snap ring in pictures).
Dripley, you made an excellent choice.  Gotta love the Made in USA!
Note:  Loctite the silver tip on the lead screw, I have had them "walk" off occasionally.
Edited by Joe_Pool
To add information
