- Replies 26
- Views 5.8k
ColoradoColt 14 posts
Mopar1973Man 4 posts
JAG1 3 posts
Dieselfuture 3 posts
With a scanner I’ll give it a shot when I leave work today and let you know how it goes.
Yes you have an electrical issue, not fuel related. I know little about electrical but a few guys found the big white connector about over the middle of the cowl was not connected all the way and solv
take apart both grounds in front of the drivers battery. One down low on the fender kinda hard to see but moving the wires youll see it there. Use couple long extensions to get it loose and clean/ san
No codes are present. My problem is when trying to accelerate, anything over around 10% throttle and it cuts out and loses all power like I put it in neutral. Barely got to 40 mph on my way home. Hopefully not a transmission issue. I had a tire blow going down the highway at about 75 last night and not sure if I knocked something loose or what. Had a p1698 code a couple weeks ago with no symptoms and cleared the code without it coming back. The problem doesn’t seem as bad once the engine or maybe transmission gets up to temp.
Any help is very appreciated.
Edited by ColoradoColt
