Weird steering issue!
- Replies 6
- Views 2k
Popular Days
Well I bled the PS system the right way instead of making a few circles in the parking lot. Jacked the rig up and moved the wheel lock to lock as I added fluid to the correct level. Definitely got mor
When I flush the system or change pumps. I jackup the front of the vehicle getting the front tires off the ground and turn the steering wheel from lock to lock to get all the air out and proper fluid
My truck got a redhead steering gear and the numb nuts doing the work put ATF in there on an 01 . Did not jack it up and didn't undo the low pressure line to bleed. He started up the truck and went lo
Just switched out my power steering fluid. Nothing wrong with the steering but I had some Walmart crap in there and wanted to flush out most of it. I didn't do a complete flush but drained the reservoir several times and replaced it with O'Reilly PSF which is Dodge MS-5931 compatible.
Got in the rig this morning and my power steering and brakes were gone. YIKES...did I just lose my PS pump??? I'm thinking not (wouldn't that be a coincidence) so checked the reservoir and found I had way overfilled it. Drained it down to the "Cold" level, started up and in 30 seconds I had my PS and brakes back.
I don't know if this a real issue or I had air in the lines or what but it's right back to normal. Any comments on over-filling or what might have happened here would be appreciated.
Edited by MikeH
