Dap 7x0010 injector problems
- Replies 33
- Views 6.7k
Cummins1401 12 posts
Mopar1973Man 6 posts
dripley 5 posts
dieselautopower 4 posts
I spoke with kaycee. He's taking care of me. Thanks.
We will make sure to get you the correct washers. Someone brought the washer mismatch to my attention Friday. Supplier sent some that were slightly smaller in height and it did not get checked befor
Ouch... That suxs. I know what you mean someone dumped all my nuts in the washer can. Sort that stuff out on the floor. Now in this case sorting copper washers and measuring every one with caliper oh
After purchase of dap 7x.0010 injectors and quad I'm having idle issues first time put in gear. 99 auto stock hx35 cai 4" mprp big loap will stall if grid heater is active. Smokes when grid heater is active and in gear. If I double pedal to back out I'm fine. Once in gear im fine until I put in park again. then same problem. I've completely removed quad ran on zero ran on 3 with timing changes. No change. Ran wire tap with ZERO SMOKE all settings. After researching alot on here I assumed I needed the quad to turn can bus fuel down on no to low psi for smoke control. I'm stumped. any advice. thanks
Stock stall converter. fass set to 14 psi. hits 15 when bucking in gear. 12 min at wot
Apps is in spec vp is reman 3 years ago. Trans has 30k on stock rebuild. 221k on stock injectors. no problems until new injectors
Tightened tubes to 28 ft lbs hold down 89 inch lbs. No change in oil height. Quick bleed started in 5 seconds after bleeding.
