2002 Dodge Ram 2500 - Things to do.
Ok...
My truck went to down after a hard run here locally. Trying to turn around on the highway and out run a semi-truck. Finally blown the head gasket. Not bad but it weeping oil out the front. Still starts and runs. Yes I know most like the smallish turbo (drive pressure) is my problem and need to upgrade. Right now with all that is going on my 2002 is going to remain down for some time and let me fix it right. I know I got to pull the head and get it inspected for sure then reinstall. I'll leave wire tap off till later when upgrade turbo can be had. Already had a nice chat with @dieselautopowerabout it.
Like I'm just about got the 2006 Dodge up and running and will be installing the new +50 HP injectors in that today and changing the oil. I'll be back in function today for business.
Next thing I need to find a full lock set for my truck the driver side door lock is so wore out even my factory orignal key (spare unused) will not open the door. I want to find a door lock set for both doors and the ignition lock as well as a set.
After having @Wet Vette car broken into I'm going to be looking for a good alarm for my truck and kill switch to prevent it being stolen. Also gotta look for one for Eileen's car too.
Want to pull the interior apart and power power the carpet out and reinstall. Looks awesome when its done because it looks like brand new again.
I've bought new seat covers 3 months ago and never install them. Including new steering wheel cover.
I want to fix all the weird quirky things in my truck that have been over looked. So I'll keep this post going on the stuff I'll be doing.
  • Replies 22
  • Views 5.7k
  • Not high boost... high cylinder pressures, 50 psi, 100 psi no matter it won't make the slightest difference compared to 1000's of PSI cylinder pressures with timing too far advanced
  • Doubletrouble
    Doubletrouble
    and another reason I don't want to go to far with mine as in power mods that is. I want reliable, long life.  I know mike has a ton more miles than I do and it's been a good truck for him, no arg
  • Mine failed where @NIsaacshas the mark. It is common place for a leak. Never thought I was too hard but like wind it up sometimes. Made it around 465K before it started weeping.
 I have to ask, and this is off topic. How do we post pics now? I tried and got a warning that said pic is to large? I don't know how to adjust my phone to make the file size smaller. Or is there something else I need to do? Never had this issue before.
