- Replies 64
- Views 11.9k
Red Rambler 27 posts
dripley 8 posts
Mopar1973Man 7 posts
01cummins4ever 7 posts
I'd be looking at the fuel pressure regulator, filters/strainers, drive belt, etc. Of course checking with a mechanical gauge or other known gauge would be a good idea, too. Your sender se
Mine runs barely open, no snubber on about 4' of line to the mechanical gauge. Same as I set it up about 10 years ago.
Yes.
Hello, I have maybe a year on my isspro gauges and my fuel pressure gauge seems to be acting up. Is the sender an often replaced item? I have a needle valve, snubber, fuel hose plumbed to my sender. My hose is 6 ft long to my sender. At idle it is fluctuating from 11 psi and at idle revving to 2k it is at 18 psi. Just trouble shooting on where to start.
