Mishimoto trans cooler
  • Replies 15
  • Views 7.6k
  • IBMobile
    IBMobile
    ssion coolerThat's a lot of money for "supposedly  better cooling capabilities".    When driving down the road The torque converter is locked up, generating little heat and good air flow over the
  • 01cummins4ever
    01cummins4ever
    I kicked the idea of replacing my stock cooler with an aftermarket vs. leaving the stock cooler and adding a derale fan cooled, I went with the latter and got the derale 15960, with the fan on a toggl
  • Threadzy
    Threadzy
    My cooler is working still.  Just like the idea it goes in the stock location with supposedly  better cooling capabilities.
Is your oem cooler going bad or do you just need extra cooling capacity?
If it's extra cooling you need get an extra trans cooler with a fan.
When driving down the road The torque converter is locked up, generating little heat and good air flow over the cooler.  Most heat increase occurs when accelerating, backing up, or in stop and go traffic especially when towing. During these conditions there is little to no air flow over the transmission cooler so an increase in size and volume would provide a marginal decrease in transmission temperature as opposed to a cooler with a fan.
https://www.mishimoto.com/heavy-duty-transmission-cooler-kit-electric-fan.html
That’s not a bad price at all!
I kicked the idea of replacing my stock cooler with an aftermarket vs. leaving the stock cooler and adding a derale fan cooled, I went with the latter and got the derale 15960, with the fan on a toggle switch when I want it on,It really keeps the temps under control, the only issue is in the coldest of the winter time  I Cant get over a 100 degree on the trans fluid, unless I’m pulling something or driving all day. The fix for that would be to add a cross over in the line before the cooler and by pass it in the winter, other than that it’s perfect for summertime towing.
I never seen that mishimoto in my search, but have no regrets with the derale
Do you have pictures of where you mounted it?
I can see benefits of their radiators, but not sure on coolers. My money would go towards a radiator if I ever need one, guessing plastic will eventually give out from age like they all do. Aluminum radiator with regular coolant changes should Las a lifetime.
I just replaced my radiator last Saturday. It   wasn’t leaking just buildup inside. It had 271,000 miles on it. Got a new one for $214 OTD. Lifetime warranty. Changed hoses and the thermostat too. CYA for summer towing. Transmission only gets up in temperature  in the summer in stop and go traffic and backing it in at home.
Two week ago I was towing my 5er with the boat behind, it about 16k LB.  Got caught in stop and go traffic for 3 hours north bound I-15 going up the Cajon pass.   Tranny temp, post converter, climbed to 250°F and stayed there.  Wish I had and extra trans cooler then.
The only one I got is in the thread that Ibmoblie posted, Its kind of tight with a short bed, If you do not have the spare tire you would have all kinds of room
Exactly why I’d like to add an additional cooler. I’m not pulling as much weight as you are though... yet!
7 hours ago, IBMobile said:
Derale is another high quality manufacture of fluid coolers.
https://derale.com/
If you get a cooler w/fan be sure to have a fan controller or thermostatic on/off switch.
Or program your ISSPro for the optional relay to turn on and off the fan. Most forget ISSPro EV2 are USB programmable.
