New Isspro R5604R Mechanical FP Gauge/R7798 Snubber- Slow Response
- Replies 17
- Views 3.1k
Mopar1973Man 5 posts
dripley 4 posts
Leaky88 4 posts
LorenS 3 posts
Replaced 5YO Isspro Gauge due to it reading 3.5 PSI higher - when compared to VPMAX liquid filled gauge from Vulcan. Both readings were taken at top of OEM Fuel Filter housing.
I have a direct custom made 1000# tested line with JIC fittings between Cab Gauge and OEM Fuel Filter housing via a New Isspro R7798 Snubber connected to Needle Valve, going into Fuel Filter housing. No Isolator.
Only thing different in new arrangement is the new Isspro R7798 Snubber - with pistons. (Correct Diesel Piston is installed) Previous Set up had the simple brass small hole Snubber and Needle valve, needle valve set so gauge responded exactly like Moparmans video.
New setup works, but Gauge is “very” slow to respond. I switched back to old gauge, same slow response.
Anyone using this Isspro R7798 Snubber with similar experience?
Thanks
