Runs rough when warm, mixing diesel and oil
- Replies 33
- Views 7k
CodyBeasom 14 posts
Mopar1973Man 7 posts
MikeH 6 posts
Dieselfuture 3 posts
Alright, hopefully this is the final update on this thread. Got the pump reinstalled early last week, and decided to take it for a drive with the new pcm I installed to establish a fresh benchmark bef
You can pop them a bit higher, maybe 310-315 just my guess. I went with 320 and I'm betting now I'm around 300-305, my load is around 6-7 now was 12-13 few years back.
The arrow is pointing toward the pump.
Hey all,
First time posting on the forum, but have used it in the past to fix some of my other trucks issues, some great information on here.
I’ve got a problem with my 1998.5, 2500, 4x4, nv4500, 263k miles. Truck is stock with no aftermarket performance mods, and it is unfortunately a 53 block. I bought the truck recently as a back up for my 1997 7.3 as it just ticked over 500k miles and is gonna need a rebuild soon.
Three weeks after I bought the truck it began giving me hard starts only after it reached operating temp. I falsely diagnosed this as a fried vp44 pump, given the fact that it still had a factory style lift pump, so I put a reman industrial injection pump on it, a fass drp lift pump, big line kit and a mechanical fuel pressure gauge on the truck. Did not fix the issue. After installing the pumps, I changed my oil and found an extra 1-2 qts of diesel in it as well. So, I bought a set of rv275 hp injectors(only aftermarket performance mod truck has), and crossover tubes.
Truck would fire up and idle just fine when it was cold, but began to idle rough when it warmed up, also the rpms would bounce from about 900 to 600 back and forth only going down the road when you popped it out of gear and into neutral like if you were gonna coast to a stop. This got progressively worse to the point where taking your foot out of the throttle from any rpm and shifting to neutral would stall the truck.
Got a opinion from a friend who is a diesel mechanic, and he said the hard starts were because of a fried ecm, and the running issues were injector related. Got another ecm and it solved the hard start issue. Still had the same running problems though. I figured I made a mistake when installing the injectors and tubes, and removed them, cleaned them, checked the nozzles, put new orings and copper washers on them and the crossover tubes, reinstalled. Torqued the injection lines first, then injector hold down bolts second. 89 inch lbs. Drove the truck around yesterday and today. Same result, truck still idles rough only once it’s gotten warm, rpm will bounce when going from a load to neutral, and attempts or sometimes manages to stall when going from a load to neutral. Also still getting diesel in my oil. No visible diesel leaks anywhere either. Tried to torque the injectors again thinking maybe they might gotten loose through a couple heat cycles, and it made one difference. Starts up in a bump, and doesn’t smoke excessively on start up or going down the road aside from a little puff of black smoke when shifting into the next gear, but I believe that’s normal.
To my knowledge there’s really only three likely places on 24 valves to mix fluids. Injector body cracked, injector seals, and front shaft seal on vp44 which seems pretty uncommon. If that doesn’t change anything I might have to pull the injectors again and have them tested just to rule that out. I’ve replaced injectors on these trucks before with no issues, so I’m not sure what I’ve managed to miss twice. I’m also not sure how to test the front shaft seal on the vp44, and pulling the inspection cover with the engine running seems sketchy. Guy I bought it from doesn’t want to return my calls, starting to wonder if there’s something wrong with the head.
Sorry for the novel, any insight would be appreciated. Thanks
