- Replies 81
- Views 11.7k
Sycostang67 17 posts
Evan 13 posts
Silverwolf2691 12 posts
wh82 9 posts
I think mikes truck is being towed around by a heard of magic ferries thats why he gets such good fuel mileage and low egt pulling with stock hx35, now its got a turbo and seemingly floats around at
I think he is getting that mpg, but he has his own driving style and set up that makes it possible. For me I just simply don't want any smaller tires then I got and I don't have patience driving at 60
Make sure its a ceramic coating or its money down the drain..
The wife is letting me spend some money on the truck, so here's what I need.
1. I just rolled over 250k miles, I know the head gaskets have a tendency to let go around now. I was thinking of doing it pre-emptively and tossing in some head studs. Is that wise or should I just wait for it to fail on it's own. What brand of head gasket should I use, I have access to Fel-Pro and Mahle at work or I can go to the local Cummins shop. I would have the head checked and worked over while it's off as well.
2. I know I need injectors, I'm probably still on the original ones. I have noticed my MPG's have dropped a bit in the last year and I am clouding the sky more that usual. I am running the Edge Juice tuner so something that would play well would be preferred. I've heard a lot about the RV275's I believe, would those work or should I look at something else.
3. Turbo, I have a relatively new HY35 with the waste gate locked down. Would have done something different when it went out but had no money at the time, had to borrow a bit just to get this one. Would it enough to just swap in an HX35 or could I do a little better? I would prefer something that bolts in though getting a different down pipe is not a deal breaker.
I just want to make sure everything will play well with the Edge tuner. I know the canned units are meant for stock stuff so I'm not trying to make big power or anything. I've tried the Quad and it wasn't my cup of tea. I don't have a blank check but also don't want the cheapest stuff I can find, that said I'm not even sure if I'm going to do the work myself. I've managed to injure myself at work several times this year and I'm finally almost back to normal so I may not want to risk hurting myself pulling the head off. Mike, what's your labor rate?
