Lower Ball Joint Flush Style Grease Zerks
- Replies 7
- Views 3k
Mopar1973Man 2 posts
dripley 1 post
Sycostang67 1 post
Doubletrouble 1 post
One of the reasons I went with MOOG was the orientation of the zerk. Very accessible. Just turn the wheel and a grease it. I turned the other one better just was not thinking on this
I've never seen that before, do you use the needle to grease them. I currently have the moog joints with the angled zerks as well which is much better than the last setup I had. The previous joints
Yes, looks like this.
For better or for worse, I just got done installing these. With a bent-tip grease gun tool they are super easy to grease, so I now have no excuse for not doing so.
I'm not sure what to think about them. I'm more likely to clean them off and grease them, but if/when the ball or spring wear out they'll be more likely to let in water/salt/grit than a normal zerk.
A Google search for that part number and you can get them pretty cheap.
