Started my truck on site the other day to come home and within a minute there's a puddle of coolant on the floor, rad leaking on the drivers side crimped edge, luckily it stops as it gets warm so still able to use the truck, I've been looking for a radiator and ouch !
Several options
Rock is  $422 to my door for a standard rad with crimped tanks, guess it's chinese this is for a purchase price of just over $100
Mishimoto on ebag $1151 to my door, no crimped tanks and MIUSA, purchase price is $750
Other option is I do have a new old stock Northern Radiator ally rad with the inlet/outlet on the correct sides but no trans cooler, would need to make mounts and weld them to the rad to use this, it is IIRC 19 or 22 x31, 3 core, I do have a large seperate trans cooler with electric fans that would work.
I'm leaning towards the Mishimoto as I don't trust chinese stuff and don't really have time to mess around figuring out the Northern
No option of buying here, Mishimoto have a UK outlet but don't stock and will not stock the 1298 rad
Is the Mishi worth the $$
  • Replies 71
  • Views 8.3k
  • Tractorman
    Tractorman
    Rather rude to change the subject like that.  What's up with that?  Oh, that's right, the subject is Radiator Leak.     Good to hear you got your radiator in.   - John
  • Only a plane ride away, might give a bit though till this covid stuff has gone away Everyone should have a proper Full English Breakfast and  a Sunday Roast once in their lives  Biggest Full
  • Why not, people here in the states, collect and drive the British Hilman vans.   There not cool like a V12 XKE or a Jenson-Healey but as we say in the car biz "there's an a$$ for every seat". My
Getting any Vaccine has a known trade off, that is vaccines weaken your immune systems ability to fight off other types of disease. That's the price you pay, so I wouldn't continue getting more jabs. Also the PCR test has a rather low accuracy rating esp. with doctors that have done research on the original development of the PCR test conclude that it is 'unreliable'. Another interesting finding is that most Americans are vitamin D deficient with one heart surgeon having a 53 % greater success rate treating heart patients in hospitals with vitamin D treatments. in their IV.
I bought some vitamin D yesterday and now refuse sun tan lotion. :thumb1:
13 minutes ago, IBMobile said:
There's sunshine in west Oregon?
We had 20 minutes of it last Monday. However, I am very thankful that our drought is over, at least in the Northwest. How about where your at Dan, is the Colorado flowing well again?
Snowpack is 141% above normal but CA is still in a drought, and they keep building houses.
Slight change of subject, I finally fitted the new radiator today in pouring rain as it really started to leak yesterday,  good job I'd got hoses as the bottom hose was past it, no holes in either so in the bed box as spares.
Also noticed the intercooler hoses are a little soft so going to get a set.
Some corrosion evident in the cooling system, thermostat housing and bottom hose outlet on the block was a bit crusty, this must have occurred before me as I always use Cat ELC premix coolant, I'll run it for a few months and then send a sample off for analysis
  • Popular Post
- John
Edited by Tractorman
7 minutes ago, Tractorman said:
Rather rude to change the subject like.  What's up with that?  Oh, that's right, the subject is Radiator Leak.
- John
We all was just waiting for the radiator to come in. :tease:
:) It arrived inbetween xmas and new year but because of Covid I wasn't well enough to fit it.
One good thing about this forum is thread highjacks/derails whatever you want to call it aren't treated like you just dropped off of planet Zog, I used to be a member of a Mopar forum here and it had mods keeping threads on track....... Like the Gestapo  err boring
Did about 20 miles yesterday and the truck definitely runs cooler with the new radiator, there is a hill that I have to drive quite regular that's maybe 2 miles from home, not a huge grade but maybe 1/2 mile long, temp was 186F at the top versus 190F with the old radiator, temp still gets to 190 as that's what the thermostat is but it does take longer, towing tomorrow so we'll see what the temp is again on a regular route so I know before the truck would be 190F or a tad over.
I couldn't flush the cooling system as all our outside taps are frozen as are hose pipes which are like iron bars, I'll give it a good flush using Caterpillar cooling system cleaner once temps rise a bit
One thing I did notice is the old rad weighs a ton
Not as I could see through the neck but I'll bet there is scale in the rad, I'll have a better look when I get time, as I said I always use Cat ELC premix so for the last 20k or so (since I've had the truck) that would have stopped corrosion and scale and I have a gallon of Cat cooling system flush so it will get some of that when the weather is a bit warmer
