I've had it with mine, they ride so dang stiff, reminds me of my 79 F-150 when I had 6 Rancho shocks on it.  I'll be pulling them off soon and tossing a set of Monroe Reflex shocks back on it.  I asked my co-worker, if I was an old man with a glass taint, what shocks would you sell me?  It's ok, she already thinks I'm weird.  :lol:  If anyone is interested in them I'll be tossing them in the classifieds when I get them out.
  • Replies 26
  • Views 4.6k
  • Dieselfuture
    Dieselfuture
    I wonder if there's different locations where they get manufactured or just plain luck. Seems like everything else there's mix reviews about it. I also found where people claim 5100 are softer ride wi
  • I have had Bilsteins 4600's for about 130,000 miles now (since 2015).  They have worked out fine for me.  The truck rides and handles good.  I have heard that the 5100's are stiffer than the 4100's.
  • 01_Cummins_4x4
    01_Cummins_4x4
    Do not get Monroe Reflex shocks!!!   My pickup had them on it when I bought it in Dec 2020. The front shocks had a date of install of Feb 28, 2020 and both the front shocks were blown out wh
There is a difference in my design I built for the least amount of drag, least amount of rolling resistance, and least amount or rotational mass. I don't care about the cool factor of wide heavy tires and lift kits. It is more cool when I hammer down and out run most lifted and oversized tire trucks.  Then having cruise EGTs at 500 to 550F even better Then getting 350 to 425 miles at a half tank is super cool when fuel is 4.209 in McCall right now and Riggins is 3.999 a gallon. So my cool factor is way better than most.
Like yesterday I opened up the beast and no time flat I was heading past 100 MPH. She is quick even running level 2 on the Quadzilla. I can hold my foot to the floor and never pass 1,200F EGTs. This applies to levels 2 and 3. Wiretap well you going to pass 1,200F.
The Reflex shocks are so much nicer, there's a rough patch on the road I take home from work every day that makes me physically shudder every time I roll over it.  Today I barely noticed I had hit it.  It's a truck so I don't expect it to ride like a cadillac but the difference is like getting hit with a rubber mallet as opposed to a claw hammer.
I got 2 front Bilstein 4600 for the front to try out from rockauto, my 5100 I took out were still in great shape, not sure how long they been on there 7-8,9 years 50-60k ? They claim that they are the same aside from 4600 is slightly softer, well the rod on 4600 is 11mm and the one on 5100 is almost 14 mm, maybe piston is same but 5100 are definitely beefier.
I drove around some today and it seems a bit softer ride, maybe after they break in it'll be noticably softer, we'll see. Here is a picture, I sprayed bedliner paint on them as I don't care for yellow under the truck that's very visible on the front, had the 5100 painted black too.PXL_20211105_135230902.jpg.6dfd91f2ef1d22249d5eb3d5b4b6674e.jpg
I have a feeling that 4600 won't last as long and I'll be putting these back on. Easy for the most part aside from driver side, where you got crap in the way.
5100’s rode amazing on my 05, and have since put them on the 03 4Runner and my only regret on the Runner was not doing them 15 years ago when we bought it. I have nothing but good things to say about 5100’s.
I was set to put them on my TJ but there were lots of bad reviews due to rig weight. Against my better judgment I went with RS5000’s, despite swearing them off 20+ years ago, and have been quite happy. I replaced the POS KYB’s the PO put on so I guess anything would have been an improvement.
Are you using the 5100 without any lift ? I am and never had a problem bottoming out. I was more concerned about going off-road and flexing the front end too much where the shock doesn't limit travel off the front axle and the spring would fly out. Plus it's always been a stiff fried I wanted to see what the 4600 would act like, so I'm going to try them out for a while on the front and see. Haven't driven truck long enough to really tell the difference.
I had a 1” front level on the 05 and the 4Runner has a 2.5/1” lift. The front of the 4Runner is using the adjustable Bilstiens.
