Another loaded 2nd gen
So I want to get rid of factory speakers, but this one has the premium audio. So by chance does anyone know if I try to get another set of new 2.0ohm for the (non oem) speaker will it work? Or do I need to gut the doors & rewire?
Next it has the heated + power mirrors
But there little, anyone know if a plug and play mirrors works ?
[Ive ordered mirrors before offline and none of the included studs have ever worked :P]
Edited by ICU_24VNUT
  • Replies 6
  • Views 3k
  • Doubletrouble
    Doubletrouble
    I bought some from Amazon that were plug and play. The studs were a bit short, had to compress the foam gasket to get the nut started but once tight they were fine. Been on there for 2 years now. Mine
You'll end up rewiring everything most likely. Everything goes to the front door speakers being the amp is mounted to the speakers. So the rear door panels, and front tweeters are wired into the amps on the speakers IIRC.
I redid mine keeping the factory radio and wiring, replacing the front speakers with 6X9s and 5.25" rear speakers, cut the wires to the A-post tweeters and added a Infinity Primus 6004a Compact 4-Channel car Amplifier — 60 watts RMS x 4.  I did have to add connectors and wires for the amp.  @Red Ramblerdid something similar but i think he change his radio head.   Picture of the booster under the drivers seatIMG_7442.JPG.5cc43ecf61f4287de9cab9a85d763e40.JPG
 I bought some from Amazon that were plug and play. The studs were a bit short, had to compress the foam gasket to get the nut started but once tight they were fine. Been on there for 2 years now. Mine are also heated/power.
I have the Infinity system with different speakers.  The PO of my truck had swapped in some Kenwood speakers and I could see the amps are still in the doors when I swapped in some new Pioneer speakers.  I don't know if they are working but they are there.
I also had the power heated hippo ear mirrors, I ordered a set of the 4th gen style tow mirrors from 1Aauto and they plugged right in.  I also sprung for the power folding with marker light as well and those two features you do have to wire in.
Alright so I've checked out LMC truck and a bunch of places and I can't seem to find a new woodgrain bezel by chance do y'all have any leads?
All I see LMC is the non infinity style dash & bezel.
Does the non infinity style just bolt right to it?
