- Replies 13
 - Views 2.2k
								Doubletrouble 4 posts
								Mopar1973Man 3 posts
								JAG1 2 posts
								coleag 2 posts
That can reveal a lot but, keep folks away it's dangerous. If you have an infrared laser thermometer that can help too. Im thinking carrier bearing by just guessing. Sometimes a rubbing brake dust cov
I've been meaning to get one for a while. Problem is, when I go to harbor freight for a $25 tool somehow I spend $200
Hello, I have an 01 24v 4x4. I took it on a 200 miles round trip last week. Within 10 miles of the destination I heard a noticeable loud squeal/screech intermediately at around 50 mph. I thought is could be my front pumpkin running low due to a drivers side leak, filled it up and drove home. On way home the noise was still in and out, towards the end it started to become more constant but only above 2-3rd gear. Now when I drive its is constant above 2nd gear at pretty much any speed. It sounds like it could be from the transmission but I was thinking more wheel bearing/ joint. I will jack up rear and update tomorrow.
What I have done
New driver/passenger side wheel bearings
New both side u joints
New axel seals each side on front axle
Took of front drive shaft and drove with it off
Greased everything
New atf in transfer case
New front brakes/aren't sticking
Flushed power steering and refilled/bleed
Noise is metal on metal(sounds like) rotating above 20 mph. With windows down it sounds like drivers side wheel bearing. Also could be transmission since I hear it through other window.
Hope someone has some input on this. Dont want to pull nv5600 if i dont have to.
