- Replies 30
- Views 6.6k
Mopar1973Man 10 posts
wil440 8 posts
YeaImDylan 7 posts
IBMobile 2 posts
I've run 4 and 6cyl pushrod engines with the valve cover off and used shop towels over them to keep the oil from spraying everywhere. You can use old rages to do the same thing, lifting one at a time
If you have fuel in the engine oil how much higher up the dipstick is it ? how much fuel ? If there is a fair amount of fuel in the engine oil you would get more "vapour" coming out of th
Best thing to do is change the oil, I'd be dropping the filter and at least tip it upside down to drain or better fit new then by all means run it a little with the rocker cover off, might make a mess
Hey all, I am back again sadly for more problems.
I'll tell the backstory and all symptoms I'm having. Was headed home yesterday and check gauges light came on. Had oil pressure but noticed voltage was not reading. Parked the truck and shut it off and saw there was fluid leaking in front of the engine. Popped the hood and the belt came off and I assume it knocked the catch can (tbh I haven't emptied it and I've owned the truck for over a year) Noticed there was fuel in the fluid (oil) leaking and I smelled raw diesel. Checked the oil and there was sure as **** fuel and a damn good amount. Forums seems to say it's either injectors, crossover tubes, or the seal on the VP44. One thing I noticed only yesterday was when I'd go back to idle while rolling in neutral, RPM's would sit at like probably 900 (the line right before 1000) and then after a few seconds it would go down to it's normal resting spot (noticeable noise in the idle so it wasn't just the gauge reading higher). I'm at a loss of what to do with this damn truck. With this new issue, I'm tempted to just find a lower mileage 24v and swap it in myself because I need to replace my head too due to an ear breaking off for the plenum holes. Also noticed yesterday morning before the belt came off that there was vapor coming from the crankcase tube, which I hadn't noticed a few days before. Truck may have some blow by out the valve cover but its not pluming like a steam engine...
One thing to add with the idle thing, tuner is currently not hooked up completely so it's running off the ECM solely. Also, no check engine light for any of this.
One more thing to add, there was fuel on the injector line nut at the VP closest to the block.. Shop retightened all of them 2 weeks ago. Would this be possibly from the vp seal leaking and running out and getting that wet? As well as dumping fuel into the timing case? Or is that line possibly just shot and I need new lines.
If anyone has any other questions and want me to clarify things, I will be happy to answer!
Thank you,
Dylan
Edited by YeaImDylan
