Front bumper top pad
- Replies 11
- Views 2.9k
wil440 5 posts
Mopar1973Man 2 posts
Royal Squire 1 post
Doubletrouble 1 post
Thanks for posting that pic, I've been wondering what one would look like with the plastics all black. Now I know. I like it!
Yes someone did me a big favour, where it was there are quite a few allotments, these are areas of local council ground that is leased to people to grow food this is rather big in the UK and I'll bet
I hated the way those plastic bits would fade to gray over time. When I still had my OEM bumper I coated the plastics with roll on bed liner, made it look a lot better.
Been doing a R/H/S rocker panel, step and wheel arch on a 04 Ford Transit van for a customer, started Friday morning and by 2.00pm ish I'd run out of MIG gas so off to get another gas cylinder, It's a bit tight on our drive at the moment due to small plant, trailers, 2 Rams, piles of logs etc and while reversing and turning hard to get out of our gates I just caught a wall, took a very quick look out of the side window and no scrapes on the wall so off I go.
The gas supplier I use is about 6 miles away and after about a mile I heard something, I assumed it was the 2 gas cylinders in the bed which were ratcheted to my 5th wheel rails moving around so I pulled over once I found somewhere which was about another 1/2 mile further on after a left turn.
Anyway I got the gas and got home not once going around the front of the truck until home....... bumper (front fender) looked different...... no top pad, pad is gone, totally ripped of leaving all the mounting tags still in the bumper, had to get on with the ford so once it got too dark I came in and checked online for pads or custom bumper plans
Went for breakfast at a all you can eat full english at a pub this morning..... same route for the first 3 miles, low and behold there is my pad propped up against a dry stone wall with a piece of cardboard sat in front of it with yesterdays date and a time on it with my reg number.
I must have run over it, no damage though other than no mounting tags ( I'll bolt it to the bumper) whoever pulled it out of the road has saved me a lot of ££
Also on the plus side I changed gas suppliers and went with my supplier that I use for oxy acetylene so took the old cylinder back to my old supplier and got £102 refund on the cylinder
Like the thought of a custom bumper though but would need to make it myself as shipping
