what controls the "wait to start light"
- Replies 10
- Views 6.4k
Mopar1973Man 2 posts
Max Tune 2 posts
Auto Computer Specialist 2 posts
Silverwolf2691 1 post
Search in articles here is the link to the WT mod Engine ECM, on the drivers side of the block,, the one on the passenger side firewall is the Powertrain Control Module or PCM so not thi
In a nutshell it is correct. Only difference I might check the black probe directly to the alternator case.
@Doubletrouble Our price depends on the service needed, we have multiple services provided for the problem at hand. Example, there is a wait to start service, a general repair service and a P0600 remo
Base Info, 1999 FASS fuel pump on the block new injectors at75 hp new tubes and lines on all injectors, new exhaust manifold 3 piece with new banks intake. Quadzilla Adrenaline Daily driver tune
The issue I have is.... there is an inconsistent time for the WTS light to come on. there is also a duration the light stays on
Some time when I start the Dodge she fires rite up half a turn and she comes to life other times she will turn over and not start until the second and some time the third try I am thinking the module that controls the WTS light seems to be in league with the issue. I don't remember it taking so long to come on. when I put the key in the ignition and turn to start without cranking, it takes 3-5 beeps before the light come on. all other dash lights come on as soon as the key is turned to the start position but the WST does not always come on at the same time as the rest of the instrument lights. then when it goes out it cranks but does not start like it should, 2-3 attempts before it starts. Does not seem to matter warm or cold
it almost seems like fuel starving. I have noticed that as soon as the light goes out on the second or third time it comes to life like it should. any guidance would be appreciated
