Rear Seal for NV5600
- Replies 16
- Views 3.1k
jlwelding 5 posts
Mopar1973Man 4 posts
Silverwolf2691 4 posts
Tractorman 1 post
I'll never do business with these people ever again. I installed a 4500 from them that would not shift with out forcing it. I called and they sent me shifting forks expecting me to install them. I had
On desktop, go to your profile in the upper right, click, go to account settings, click, then go to signature. On mobile, tap the three bars in the upper right, then tap on account setting
Call C&M Gear Works. Their here close to me in Springfield, MO. I bought all my t-case and nv5600 parts/seals from them when I rebuilt both. They will have whatever you need - in your case a rear
I dont know why Im having so much problem finding the right seal. I went to napa and they gave me a 22049, I should have known better cause it popped out in 3 miles, to easy to drive in. So I go to Aline and he couldnt find anything for a nv5600, he had a seal for a 5 speed so I put it in and it leaks, I put another one in because I didnt lube the seal thinking running it dry may have caused it. Nope, it leaks too. The original seal was a 33029 and cant find that seal anywhere. I was hoping someone here might have the right number before I pay 10 times to much for it at the dealer. Thanks
