Rear Seal for NV5600
- Replies 16
- Views 3.4k
jlwelding 5 posts
Mopar1973Man 4 posts
Silverwolf2691 4 posts
Tractorman 1 post
I'll never do business with these people ever again. I installed a 4500 from them that would not shift with out forcing it. I called and they sent me shifting forks expecting me to install them. I had
On desktop, go to your profile in the upper right, click, go to account settings, click, then go to signature. Â On mobile, tap the three bars in the upper right, then tap on account setting
Call C&M Gear Works. Their here close to me in Springfield, MO. I bought all my t-case and nv5600 parts/seals from them when I rebuilt both. They will have whatever you need - in your case a rear
I dont know why Im having so much problem finding the right seal. I went to napa and they gave me a 22049, I should have known better cause it popped out in 3 miles, to easy to drive in. So I go to Aline and he couldnt find anything for a nv5600, he had a seal for a 5 speed so I put it in and it leaks, I put another one in because I didnt lube the seal thinking running it dry may have caused it. Nope, it leaks too. The original seal was a 33029 and cant find that seal anywhere. I was hoping someone here might have the right number before I pay 10 times to much for it at the dealer. Thanks
