- Replies 13
- Views 4.1k
Mopar1973Man 5 posts
5akman 4 posts
LorenS 1 post
Doubletrouble 1 post
Well the tune has a small problem with the fuel map. Did a modified version of my normal empty tune. I've see what I've got to change up and have a solution. What was happen start yo ramp up on the up
100hp DAP injectors (8 x 0085) Yay, someone else with those injectors! I bought mine months ago (or a year and months ago, can't remember) but still haven't installed them.
Soon. I'm going to finalize the tune on my trip to Cally. I'll be packing up today and heading south to Parma. I'll monitor and tweak the tune as needed.
I've got a towing tune coming together. I build a base tune from my economy tune. Tweaked it for use on my Jayco RV which is 31 foot long and typically scales in at 8,000 to 8,500 pounds.
As for today I was using my BigTex trailer and headed back down to Middleton, ID to put up my free bed. King size, dual zone adjustable. I had a 1/4 tank and left made to Council, ID and got 30 dollars of fuel (5.6 gallons) and continued to Middleton, ID loaded up the bed and headed out grab 20 dollars (3.8 gallons) of fuel and continued back to Payette, ID. Basically traveling 100 miles on about 5 gallon of fuel. Trailer was empty down (1,800 empty weight) and loaded no more than maybe 2,000 trailer and any other cargo in the truck (maybe an extra 100 pounds). When I was at Payette I got 100 dollars on my Maverik Nitro Card gives me 6 cents off a gallon so it was 20.004 gallons at $4.999 per gallon.
I changed up the timing and it builds boost quicker, holding on and grade it might bump the added fuel zone little bit but it falls back to my stock fuel zone pretty quick. EGTs are cool, even on a 7% grade no more than 900°F at 65 MPH. Tune is smoke free, launches good with a load, easy to build power. Even wide open I struggled to even get close to 1,200°F even on the grade passing. Just cruising on the Interstate at 80 MPH (2,450 RPM) I was just about 750°F.
This is just my first setup but I'm planning on heading to California with my RV so more tweaking will be performed. Just for the first run I'm very happy in the power even though I'm only using level 3 (CANBus fuel only).
