Banks high flow intake elbow and OEM grid heater replacement
The project starts as soon as I feel like braving the weather.  Main point is to prevent the OEM grid heat nut from finding it's way into cylinder 6.
I am not a huge Banks guy but the parts look well made and everything I need is here.  Huge thanks to @dieselautopower for the parts!
  • Replies 27
  • Views 10.4k
  • well I think it is in.   i need to let me phone charge before I can check for codes etc, but overall good.  Few minor complaints that I will document.
  • This morning the thermometer is reading -20*f.  Truck fully cold sitting outside started without much hassle.  Idle was a little rough for ~60 seconds then smoothed out.   I feel better about the inta
  • I was able to test the intake heater down to about 0*f today.  Truck is noticeably harder to start now, but not hard to start if that makes sense.    Here is a picture of the OEM grids with
Has the killer grid heater bolt fixed with later 4th Gens?  I picked up a '21 3500 and thought I heard Doge had fixed it.
It’s still a potential issue. Doing the bolt wiggle test at each oil change is recommended.
  • 2 years later...
On 12/6/2022 at 7:42 PM, Me78569 said:
Way less draw, which might be an ok thing.  We will see how it starts when it is -40*f
I know this is an old thread, but thought I would mention, I just seen where Banks is offering a 2nd, 3rd & 4th add on heat element available to add to your intake. Just FYI
Funny with so many deleting the grid heaters. Crazy part is most think its interfering with air flow but only above 600 HP. Then you might gain like 5 to 10 HP.
  • 5 months later...
I just deleted my 16 Ram 2500 Cummins, with a non-Banks intake manifold with grid heater, and intake plate, and the egr valve and cooler delete. I still need to install the DPF, DEF, and SCR delete yet.
I know Banks makes great products, but if you think about the size of the intake manifold, and Banks claiming theirs flows the most CFM, it's still gonna hit the intake chamber in the head, where that will be the bottleneck. The intake chamber can only flow the same amount of air unless you buy a head that's been ported or modified to flow more cfm than the stock head. I just couldn't justify spending $720+ for an intake manifold when my whole delete kit was $1,225 for tuner with delete tune and performance tunes, and EGR, DPF, DEF, SCR delete.
My DEF reductant sensor started being wonky and constantly flopping back and forth between empty and full. A new sensor was like $700+, so I bit the bullet and deleted my truck a little sooner than expected.
Could you write an article on your experience of said delete? Source of products? Etc.
