New VP44 No Start! Codes P0382 , P1689
- Replies 23
- Views 5.9k
cumminsman87 9 posts
Me78569 3 posts
Hutch24v 3 posts
Great work! 2 posts
I watched your video. Your "wait to start" light went out at 15 seconds into the video yet you didn't crank the engine until 45 seconds into the video. Why did you wait? Since it sounds
You can control the FASS fuel pump, if it has a relay, from under the hood and bypass using the key by using a jumper wire. Attach the jumper wire to terminal 30 of the FASS fuel pump relay then the p
Ok I get it now. If it is grounded that needs fixed. If it's open that means the wiring is okay ie not rubbed through somewhere. So they just assume the ECM is bad by a process of elimination. Bewa
Hello Guys,
New to the forum. Recently bought a cab swapped 2001 24v 5.9 6 speed with a 15x VP pump. I bought the truck not running and dont really know alot about the mods that have been done to it. It does have an edge tuner and a dual turbo installed as well.
I have replaced the VP44 and still have a no start. I have bled the return line banjo and 1, 3 and 4, to the point of flowing good. I have 20psi coming off the fass lift pump dropping to 10psi while cranking. I do have power and ground at the vp plug. I have also tested continuity and grounds from ECM and PCM.
Replacing the VP44 did change the sound while cranking. Before it was just cranking. Now it seems like it is trying. Looking to be pointed in the right direction. Thanks
