- Replies 41
- Views 3.3k
Doubletrouble 15 posts
Mopar1973Man 12 posts
Tractorman 7 posts
LorenS 3 posts
Thank you John for this inportant discussion and information. Important enough to know that 'Death Wobble' just isn't the wife dancing on your grave. Thank you.
NCP (Napa's premium line) is made by Moogs parent company, hence the same part number as Moog. While I'm not a fan of actual MOOG, I do prefer to use NCP napa chassis components. After someone so grac
I am also running the Centramatics - installed one year ago (10,000 miles ago) this month. I installed them for a particular reason. I had purchased a set of four commercial winter tires for a good
Ok, I've had a this issue before but very random and not very often at all. Yesterday I was on the highway at 60-70 mph and hit a bridge transition and it went nuts! Again less than a mile or two later. With traffic behind me I had to smash the brakes down to 25mph to get it to stop. Luckily no one rear ended me!
I absolutely have to get this sorted out! I replaced the track bar approximately a year to year and a half ago. It was a lower priced one from Rock Auto. I have replaced the left outer tie rod as well.
I have read that the track bar is usually to blame but I want to be 100% sure it is fixed for good this time.
Any advise or guidance here would be appreciated.
Also, just to bring this into the conversation, would it be advisable to upgrade to the heavy duty mopar steering kit? Maybe the 3rd gen track bar? I don't know. I just need this to stop once and for all.
