New IAT, temp goes above 293, watch it drop on the code reader
- Replies 43
- Views 6.7k
Tim Waldo 16 posts
Mopar1973Man 10 posts
Tractorman 8 posts
Doubletrouble 5 posts
I don't know how attached tou are to that truck but just for comparison, $13k would get another running truck in my area. I've seen them go for less than 9k, might be worth looking fir a donor
Anytime poor wiring connections are a possibility, the symptoms may or may not be predictable as the resistance value can change at any time for no apparent reason. The only time an electrical connec
Check the intercooler for some type of restriction performance problem. It may not be sheading heat.
So the last code I had to deal with was one for the IAT... ordered a replacement and put it in... The old one looked "melted" https://photos.app.goo.gl/T5s5ek2kwEQnGqBE6 and I discounted because I haven't touched it since 2008.... WHAT would make the temps in the IAT chamber go up so fast? Burnt valve? I don't have an exhaust brake...
ECM??? would the ECM somehow confuse the interpreted signal? I mean I did watch the temp slowly drop when I turned vehicle off.
Vehicle did get new injectors, it is possible valve clearances got "changed", guy doing the work stated the rockers appeared "loose" but I don't know on which valves. I don't think this is a new thing, no codes were being thrown BEFORE I had the VP44 issue.
