47re, fuel leakes, general updates and hellos
- Replies 26
- Views 5.6k
Evan 13 posts
Mopar1973Man 9 posts
JAG1 2 posts
Great work! 2 posts
Spent 40 minutes on the phone with transgo talking about the 47re valve body and pro recalibration kit. I wanted to make some refinements but didnt want to pretend i knew what i was doing.
Rather tough for me. Now with my Quadzilla on its totally clean, no smoke. Now select level zero Now ive got a dirty Beast. Sad part is the power is greatly reduced, and EGTs are higher, t
Timing. When all the fuel is burned in the cylinder and nothing is left then when the exhaust occurs there is little expanding gases hence lower EGTs. Retard timing which will have burnin
So Mike let me come hes selective about that ;)
Lots been going on. Picked up a f150 to drive while my truck was down but ended up giving it to my daughter.
So i was out a daily driver stuck driving our work truck a 04 cummins.
My tourque convertor went out with 170k on it. So i bought one local after seeing the guts they put inside
The convertor in my truck was supposed to be low stall it was stock, didnt have a one peice fiber, it wasnt brazzedd for support basically the cheapest thing you could get
So i got a lower stall billet piston brased, one peice fiber, reamed for more volume.
So i decided to tear the case down
Like completly down
Orderd the gpz clutch kit from revmax a set bushings for the trans, seals throughout out.
Made the tools to press it apart and together. Was scared a few times i did it wrong. Over drive took me 3 attempts to be confident i had it right.
Over drive unit with 4" exhaust pipe in the press
Long peice of pipe because intermediate shaft is inside to line up over drive unit.
that is a 830lb spring in overdrive unit
For some the transmission has always been the most interesting part if the truck for me.
I now kinda know how the fluid flows but still no clue how it actually works. It just does i guess.
Also talked to dynamic alittle bit hes a big help.
On tearing down my trans i found a basically stock tranny. Oem fiber counts with a kevlar front band pretty dissapointed in this find.
Revmax kit puts more fibers with machined pressure plates to fit them. The raybestos gpz fibers are supposed to be good.
The valve body already had the transgo tfod kit in it so leave well enough alone.
Nope i picked up the transgo pro recalibration kit.
The recalibration kit is pretty in depth took me a few hours to go through step by step. As in all things some love this kit and some hate it saying it run uneeded pressures.
The kit supplies special seals to withstand the pressures on forward clutches all forward gears now capable to see full pressure
All in all it took about 2 weeks for me having no clue what im doing to follow the atsg book step by step.
I maybe could have done it without the book but k owing where and how to check fir clearances and end play was critical.
I did price local shops but 3-6 weeks out and 3500-5000 price guestimates made me pull the trigger and chance it.
It did turn out well this transmission is freaking tight were as the last refresh was like a loose rubber band and i thought that was good.
With the extra clutches lower stall better convertor and reworked valve body she will pull a house down without touching the throttle
Ounce on the throttle it flat goes no slipping crisp firm quick shifts. Zero hunting any where
Ive bumped smarty tourqe to 6 on catcher 9 . Before it would slipp on the bottom . So had tourqe at 4
Seriously thinking about getting a real programmer like you guys all run now.
notice the park rod clip
At the end of the atsg book you put the over drive unit on and it congratulates you for finishing. Im like yup if it even works.
Im now watching for another 47re so i can slow build it over a couple years.
Anyways ive got a few hundred miles on my tranny now one that this time i actually know whats inside because i put it there .
So far realy liking it. One of those things where it shifts gears the turbo screams and you just grin n push the pedal down alittle farther
Anyone can do this the 727 is pretty easy to work on with the picture book in hand
Ive orderd seat foam/covers, door grab things that hold armrest on, head light lenses cheap clear to put the morimoto leds in (still badass)
Guess well just run this truck till it turn to dust
Ill be doing away with the casto vwashers on front axle and fabbing adjustable lower control arms to be able to set castor easily and not have it change while driving.
Fixed fuel leak on return line on back of the head while trans was out. Verfied it doesn't still leak there.
Still havevantitheft active as you have to prime pump to start it. Can still smell it but dont know where its leaking.
Randamn sunset i shot and me in night jeep run with the crew.
Thanks mike for allowing me back.
Ive been unable to post for quite while but have lurked here and there glad to see lots of old names .
Also got a new phone and lost mikes number and a few of yours that i knew were in contact with mike.
Then today i noticed i most likly could get mikes contact info back from the dark deep web and i was correct.
Walla good to be back
Edited by Evan
