truck failed it's MOT test today
- Replies 15
- Views 3.5k
wil440 7 posts
Mopar1973Man 4 posts
Tractorman 2 posts
IBMobile 1 post
I also think the front brakes on trucks that haul heavy loads with automatic transmissions have a big impact on heat generation conducted from the rotor to the hub. Excessive heat will harden the sea
Here's pictures of the bearing carrier without the wheel carrier
The bearing race that is apart was really badly damaged here it's called brinelled, bit like the chicken and the egg, which first, did the race and rollers wear thus allowing water in or did water
Took my truck for it's yearly MOT check today
failed on drivers side upper and lower ball joint.... no problem got those
drivers side wheel bearing ..... haven't got one, have a 2006 to 2008 but my guess is it will be different ??
Here in the UK a lot of replacement wheel bearings are just that... just the bearing and not the whole thing, we just press the 2 peices apart, remove the bearing and repress back together, is this possible on a 98 4wd with no front ABS, I have a good bearing company not to far from me so if it pressed apart and there's a number on the actual bearing it may be a go ??
Changing the bearing would be quicker than ordering the whole thing from rockauto
