I needed to put the 7x12's on the shelf.I wanted to see if i could get better mpg.As well as help my new vp last a little longer.I traded some guy.He wanted my old hx40.I wanted his rv injectors.So he gave me some cash and the injectors,i gave hin the 40.I sent the injectors just to get freshened up.The guy at the injector shop told me they were crusty.He fixed them up and did whatever them guys do and sent them back. So i put them in.I had hard cold starting problems.Somehow air was getting into the system.I did find the return line needed to be tightened.Did that little to no change.Then i remember the injector guy saying something about (They should work themselves in)They did not seem to be doing so.So i added 1 qt 2s for 3/4 tank of diesel. I am happy to say the 2 stroke is helping my cold start up.Today it is just a tick away from being perfect. The extra lube in the fuel is helping the injectors seat and not bleed down :hyper:
  • Replies 23
  • Views 5.6k
i love that stuff..can't happen to wonder if the white bottle of power service...say...every other tank or something would hurt.since it is cetane booster if that would help with starts...i believe last winter ISX did a write up on that.
Well that is the only thing that is keeping my misfire issues under control I sure hear the misfire more so if I forget to add to the fuel... :rolleyes:I know my injectors are already seen better days and over 400K miles... But for free I couldn't complain...
Might also check the crossover tube o-rings. I just replaced my injectors and most of those o-rings were shot.
I replaced the tubes with brand new ones.(cummins)I diddnt know if they had clogged up.I ran them in the parts cleaner backwards so the funk wouldnt get forced in more.All of the o rings are new.
I recently read about two stroke oil mixed with diesel for better lubeing of the vp44. I've been adding about a quart to every fill up, which would be a little more than the recomended 0ne ounce per gallon of diesel fuel. I have noticed that my motor runs much quieter and smoother. Diesel is now three bucks a gallon so the extra two bucks for the two stroke isn't going to break the bank. I've now got 198,900 on the old girl and she is running just fine.
I've been running 2 stroke for a while. I premeasure the TCW3 into a quart container for a half tank + fill up. I carry them in the door pockets so have enough for a decent road trip without needing to measure again.
I do that too.:thumbup2:
there prolly is no such thing as an overdoes...unless you pump 32 gallons of it in there!!:thumbup2:
Actually there is... Once you start down below 100:1 ratio you'll start to notice the exhaust color turns more grey in color and MPG's start to slide down some. This is because now you cetane number is too low and the fuel isn't burning fast enough to completely burn. So there is a balance ot the fuel...
i was j.k. on this one.
Don't use to much 2 stroke oil, i sent my injectors off to get cleaned and pop tested (50k on them, rough idle) and the shop called me and asked what i was using for fuel. I said #2 with 1 qt of 2 stroke at every fill up. He said quit using it as it has gummed up these injectors really bad. Just my 2 cents. I no longer use it.
do u ever pump bio blends? i have seen a lot of photos where the all kinds of stuff was gummed and corroded because of bio. i have been running 5% bio and get a nice bump up in MPG. when using bio, i never add 2 stroke. i also go a little less than 1oz per gallon when pumping straight #2 :2cents:
hhhmmm...sooooo...what does he recommend for an additive.before i switched to 2 cycle ..i was using lucas for years and never no problems...seems quiter with 2 cycle tho...what is his thoughts?
I just started using 2stroke about 3 months ago. The engine is definatly quieter and smoother.
He told me to run nothing, I was running 1 qt every 28 gal fill up. I don't anymore. I wasn't trying to stir the pot i was just saying.
no ruffled feathers here..everyone is entitled to do what they want..its cool man!!:thumbup2:
