Throttle Assembly Re-location Mod
- Replies 14
- Views 3.7k
Tractorman 5 posts
01_Cummins_4x4 3 posts
Mace 3 posts
Mopar1973Man 2 posts
I truly believe that the amount of apps sensor failures are because of the vibration they absorb being engine mounted. Ram eventually went to a pedal apps setup in the later 3rd gens. Well
Awesome mod John! I'd like to do this to my 01. Can you please provide the length and measurements of your bracket? Can I do this without issue with my auto trans throttle valve cable?
It used to be mounted on the left side front of engine. The piece in the photo can be removed, as well. I left it in place because that is where my coolant filter is mounted. It uses the two holes
First, and foremost, I was inspired to perform this modification by @Mace (a new member with lots of knowledge) who provided the idea - I never would have thought to do it on my own. I also want to thank him for providing the "how to do it " information as well as a list of parts.
Well, I am finished, but I didn't do it the way Mace from Kamloops did it and in no way is my modification any better that what Mace did - in fact, some may prefer his modification over mine.
After much of going this way and then that way and then repeating myself, I just finally came to a stand still. So, I stopped working and started thinking about what I really wanted - which was:
* I want the engine noise that is being transferred through the throttle cable into the cabin - Gone!
* I want the APPS throttle assembly removed from the engine.
So, after re-thinking this AGAIN, I thought why not just remove the assembly from the engine and re-mount it elsewhere in the engine compartment? That way, nothing changes:
* I keep my fast idle solenoid
* I keep the adjustable throttle stop
* I keep the 45° sweep of the APPS
* I eliminate the transmission of engine noise into the cab.
* I get the delicate APPS away from the pulsing, vibrating engine!
So, that's what I did. There are no changes inside the cab. I just relocated the complete throttle assembly to a place between the brake master cylinder and the oil dipstick tube. I fabricated a custom mounting bracket and used two existing bolts on the the hydraboost / brake master cylinder unit for mounting the bracket.
This photo shows the custom fabricated mount and its new location.
Two more sets of bolts and nuts and the throttle assembly is mounted.
Everything is easily serviceable. The throttle unit can be unbolted (either from the hydraboost or the APPS mount) with just two fasteners. The unit can be lifted up and laid flat for throttle cable disconnect / replace. The APPS can be removed / installed without removing the throttle assembly. The idle stop and the fast idle can be adjusted with the engine running. The fuel filter is easy to remove / replace.
Now for the best news - the noise is gone! Absent! Doesn't matter whether or not my foot is on or off the throttle or if cruise control is engaged or not. I didn't realize it until now, but that rattly noise was always there to some degree at every throttle position - including foot off the throttle. When I turn on the Fast Idle switch now, the tach goes to about 1150 rpm and is steady as a rock (used to float +/- 50 rpm).
Shoulda done this about 393,000 miles ago!
- John
