NV4500 parts
Trans was making funny noise. Tore into it and discovered pieces of a gear in bottom of case. SO, where is best place to source heavy duty parts for the nv4500?
  • Replies 3
  • Views 1.3k
  • Doubletrouble
    Doubletrouble
    I bought my parts from a combination of allstate gear and torque king I believe. I had to replace the input shaft, main shaft and counter shaft. Mine was pretty trashed. I also replaced the tail ho
I also replaced the tail housing, OEM was an aluminum peice, I replaced it with a cast iron piece from torque king.
