Yoke Grenaded
Was pulling my car trailer the other day (empty) when I got into the throttle just a little to get across the intersection, the rear yoke decided it'd had enough. So, does anyone have any suggestion on a good strong yoke? Does anyone make a yoke that uses u-bolts instead of straps? I have changed the front over to u-bolts but haven't found one for the rear. Dana 80 axle in 2000 ram 2500 L6 5 speed.
  • Replies 12
  • Views 1.7k
Solved by Lund1990
Looks like a U-bolt style was used on the 2nd generation 3500's, but not the 2500's. I think the U-joints are a 1410 series on a U-bolt style. A conversion would be possible, but probably costly.
Did you do a failure analysis to determine whether it was an instant failure, or one that was coming on slowly? The photo doesn't show all of the broken area, so it is hard to tell if there was a crack first, then a breakaway.
As far as I know, the OEM type end yoke is not problem connection.
- John
I picked this piece up from the intersection the next day. Thinking it was possibly cracked already as I don't think it would have gotten t that dirty in 1 day.
Also. I tried searching as a 3500 and still could only find the strap style for the rear axle
Had you noticed any driveline vibration or noise prior to the event? Had the driveline been removed and re-installed recently?
Was the rear u-joint still in good operating condition disregarding the damage from the end yoke failure? In other words, were the end caps lubed, not dry?
How do you use this truck? Does it do any sled pulling? burnouts? I only ask these questions just to cover anything that may generate shock loads to the drivetrain.
Personally, I would just replace the parts needed with the OEM style end yoke.
After seeing what happened with your truck, I think I will inspect the end yoke on my truck.
  • - John
  • - John
Haven't noticed a vibration. It had been a few months since I had the the driveshaft out. I keep it greased, but that u-joint had been kinda tight since the day I installed it. I don't do pulls or burnouts. (Tires are expensive af) Only thing I really do is get on it hard, but I never drop the clutch. I had my car trailer behind me (empty) and was taking off in 2nd. Had it revved up only a little bit and had let the clutch out nicely. It was actually completely engaged when the failure occurred.
I'm hoping my driveshaft isn't ruined. Currently it is stuck in the transfer case. Hoping its just from getting kicked forward, but I fear it may have spun on the teeth. Haven't dropped the diff cover yet either as its been far too cold. But we're looking at 45º on Tuesday so I'll be under it.
4 hours ago, Royal Squire said:
Wonder if the transmission seized
Nope. Driveshaft was still spinning afterward
And this is why I went to a flange.
Edited by Mace
  • 4 months later...
Off of what? I was wanting to go to a ubolt style but couldn't find one. Have part numbers by chance?
Holy moly! Either a bad casting or something else was wrong for that carnage to happen, or just plain bad luck. I would not think that's a strap issue, maybe improperly seated or over-torqued, or really bad ujoint.
I think the last one I got was oriellys, I dont remember, but you can check out C&M Gear Works. Their here in Spfld, MO but they ship, and have pretty much everything for our trucks drivetrain wise. Great source for rebuild parts!
Id go back with the same thing personally!
  • Solution
I've gotten it back on the road. Robbed the yoke off my 98 that has a cracked block. Oddly enough I just bought another 98 1500 two days ago cause the body is in damn decent shape. Body swap to my 2000 that this yoke blew apart on.
