Another simple enhancement that don't cost a bunch of money is straight pipe the exhaust. Beware in some states it is illegal to be without a muffler. Now in some states a turbo is considered a muffling device. Some people think it just to loud. I will admit that without the muffler in place is it louder. I've been told that my truck can be heard up to a mile away. Now besides the noise and legal stuff. The bonus to straight piping the exhaust is that the engine can breathe easier. It will reduce the pyrometer temperature, increase horsepower and torque, and increase your fuel milage. Basically all you need to do is measure how long the full muffler assembly is and get a piece of 3" exhaust pipe and maybe a new set of clamps. Once you got the pipe have them expand the ends so they will fit over the existing pipe. So now when you do this you going to have to fight a little to get the old muffler and resonator off. I used a torch to heat the clamp spots up to get the muffler assemble off. Then slide in your new pipe and clamp it down. I've welded in some re-bar hanger to mount back in the rubber hanger on the frame to help hold the pipe up. http://mopar.mopar1973man.com/personal/2002/muffler-delete/muffler-delete.htm
  • Replies 50
  • Views 12.8k
Yep, that's almost exactly what I did to my '99 when I had her. Only thing different that I did was to use some 3" into 3" exhaust couplers and use a few extra clamps. I cut out both the resonator and the muffler on the '99 and she was obnoxious loud. On a hunting trip to North Dakota I could hear my truck when my buddy was driving almost 2 miles away when he was on the throttle!!!! 8-) I do miss that truck and the sound, but I have to admit I do the quiet of my 04.5 with the MBRP muffler.
  • 2 months later...
Missing pics again...
Must be your 'puter Doc. I can see them just fine!
Yes it must have been - I can see them now.
Your right the pic link were old and point to the old address... I'm getting things fixed up... :rolleyesThanks for catching the down links... There are more to be fixed too...
Hey now, you aren't supposed to tell Doc that his 'puter is fine.......... >:) He was supposed to think his stuff was all messed up.................. :Mad
  • 1 year later...
M73M,I keep getting a problem loading page notice. I want to check out your link for the muffler bypass.To get it to be not so loud, should I keep the resonator or the muffler. Which one would be the better one to delete? Go with a glass pac instead maybe? Try to cover :moon Dave
Hmm for page loading problems... http://mopar.mopar1973man.com/personal/2002/muffler-delete/muffler-delete.htm try using IE browser on my site... As for loud it only loud when you got your foot on the carpet. As for keeping it quiet you could go with a glass pack which exact like the resinator but the stock rtesinator is 3" on one end and 4" on the other... :mad
I was wondering about the res inlet & outlet, 3 in, 4 out, cool. I was thinking of keeping the res but read on other sites that it's quite restrictive. True? So if I keep my foot out & off the carpet it won't be so loud if I want to try straight?Dave :thumbsup
I was wondering about the res inlet & outlet, 3 in, 4 out, cool. I was thinking of keeping the res but read on other sites that it's quite restrictive. True? So if I keep my foot out & off the carpet it won't be so loud if I want to try straight? Dave :thumbsup
Restrictive??? LOL The stock resinator is nothing but a straight pipe thought a muffler can packed with fiberglass. The pipe inside the can has holes drilled in the face of the pipe. As for noise... Truely they are not to bad as long as you keep your foot out of the carpet. But sounds awesome in a tunnel or under a bridge at WOT... LOL
Speaking of loud I was putting 5" exhaust on the other day and fired it up with just the down pipe and 3' of 5" pipe and rattled the shop walls :D
Another way is to use adapters or weld the end of a piece of 5 in pipe, it looks like a muffler. To make it a little quieter add a spot baffle 4 in from the inlet, the same diameter as the inlet. Two pipe diameters from that cut a rim baffle with the center the same dia as the pipe.A little more than a straight pipe, but for those that have muffler laws it looks right and with the 2 baffles it is a muffler.keydl
  • 2 months later...
I just tool my magnaflow muffler out, it is 4" all the way, sounds great and not that much louder inside but outside it is great.
IAB,I bet it does! Anyway to have that put on YouTube for all of us to enjoy your greatness? :thumbsup Dave
  • 4 weeks later...
Here in Pennsylvania where I live they have begun checking for mufflers at State Inspection.They are now NOT considering the turbo as a muffling device and owners are being asked to have one in place.While many of the local kids here think its not fair and a pain in the tail they are not considering that it could be worse.They could stand by the Federal regs which state that if the truck was equipped with anti-pollution equipment(ie-resonator/catalytic converter) then it must be in place.So when my inspection mechanic gave me the heads up a year ago I just gave in and placed a muffler in my system and did not look back.They are also now cracking down on diesel pick-up owners who are stack equipped and not using heat shields.They are allowing a stack in a stack style as a heat shield instead of the gawdy nasty screens which are on class 8 rides.Also of note if you are stacked equipped here in PA you also need a muffler and they do not consider the square tube stack box as one..........Andy
I bought a 4" SS exhaust... straight through with the center pipe small louvers (mounted facing down stream of course). It is a muffler but sure can't have much restricton. I seem to recall they're available in all sizes. I shopped all over & finally bought an exhaust kit on e-bay. Took a week to get here but was as promised.Russ
