Steering column gauge mount?
I'm curious if anyone has a picture of a steering column mounted gauge on a 2nd gen truck? I'm wanting to add a drive pressure gauge and think that would make a good place to mount it but I'm a little worried it will block my view of the speedo?:shrug:
  • Replies 56
  • Views 16.2k
That is pretty neat. I really like their 2 gauge pod. I might go something like that. Just got to figure out what else I want to monitor... Maybe a trans temp?:shrug: Wonder what else would be good to monitor....:shrug:http://www.puredieselpower.com/catalog/19982007-dodge-ram-gauge-windshield-above-mirror-mount-p-1359.html
  • 3 weeks later...
i was looking for someplace other that the a-post and the steering column when i dreamed up this setup.
Posted Image
Posted Image
:smart:Bullett83 that is probably the most awesome piece I have seen in all my years of diesel forum whoring. It makes more sense and is more convienient and out of the way than the pillar mounts. You should get together with some production outfits and get more rolling out you could do pretty dang good on that idea.:drool:
:iagree: Wild & Free is right... I would jump on one of those if I could buy one... :drool:
i think it would be pretty expensive to start making these. it's actually the factory dash bezel that i modified. that would be a pretty big mold. the materials weren't all that expensive to make this, it was just a lot of time to fiberglass and blend it to look nice. but thanks guys, this was the first thing i modified on my truck when i bought it. since then, i've made a new shifter and knob, and a version of a twin ram intake.
well dang:banghead:!!! well if you dont mind sir i would like to have a friend of mine try and mimic this?
Sorry in advance for 100 questions. I see from your post, you used fiberglass... mat? cloth? putty? Did you use a form(s)? How are the guages held in? It doesn't appear to have access or at least not much access from the rear. I've had my dash bezel out recenly so I know that part pretty much snaps out with care.
i ordered a piece of plastic round stock and turned the pods out at work on the CNC lathe. then i used a product called Kitty Hair for stucture to hold them together and into the dash bezel. finished it off with some plastic epoxy repair. the gauges are simply hot glued into the pods, you are right about not much access from the rear. i used hot melt because if you want to get them out, you still can, hot glue isn't the strongest stuff out there.
Hey, bullet, CNC? How about offering the unfinished pod shells? 1 guage. Let the guys decide how many to line up & epoxie. Just having the blank would be a great service.Russ
i could certainly offer the pods, but i really am not sure if everbody could seriously cut them into their dash, (no offense). and be happy with the results. it takes patience. i grew up with wood working tools and such, and have watched a lot of vids on customizing things. (also helps to be a machinist) it is very easy to go in the completly wrong direction when you start into something like this. and i really mean no offense, it takes some guts to cut into something as important as your dash. i mean you look at it everday. i took the idea from a diesel mag i read, they cut a laptop into the dash of a chevy. the rest was imagination. and perhaps this is a discussion for another thread as well...i seem to stir the pot away from topic with my pics.
Hmmm. I was initially thinking to notch the rear of a guage pod to match the trim bezel... It's tough working without spare components to use as a form. My grandfather was a millwrite & a cabinette maker (his tools are still in the family), my father was an inventor with many patents... I'm constantly tinkering to create, customize or improve items. Unfortunately nothing to make me "rich". I was a partner & head mechanic in a boat marina (17 years) & later worked custom installing marine equipment & fleet, Police, Fire & EMS electronics. When one starts cutting holes in someone elses expensive toy, you'd better have thought of everything.I have some manual machine knowledge... I took it in school back in the dark ages. I own a unimat & a small South Bend lathe. Thinking... (and you though that smell was a tire burning)Russ
