Head Bolts "N" Studs
- Replies 20
- Views 11k
JOHNFAK 6 posts
diesel pap 4 posts
LiveOak 3 posts
Wild and Free 2 posts
Starting this for a discussion as well as for FYI for those interested
Discussion thead here
http://www.cumminsforum.com/forum/94-98-performance-parts-discussion/344262-mighty-diesel-cylender-head-bolts-anything-good-bout-em.html
product here
http://www.mightydiesel.com/store/index.php?cPath=108
Speculation here
Tony from Mighty Diesel is using their Houdini headbolts, (12mm) running about 60PSI boost.. a small S400 running about 575HP on a marine headgasket (.020" over stock thk) and those bolts.. no O-rings. And he's been pulling in the 2.6 class like that for a while. He claimed a customer has run their bolts at 100PSI boost (70PSI regularly) and they hold his HG fine. If I'm not mistaken, the guy running 100PSI boost on these bolts was running a marine HG, no O-rings.
I have my doubts and concerns about them but I have been pushing 60PSI (or a hair more?) so I'm also worried about the stock bolts holding up.
