Annoying tick coming from No.6 Exhaust Valve
- Replies 19
- Views 6.7k
cumminspower 8 posts
ISX 2 posts
Wild and Free 2 posts
Blueox01 2 posts
I have pulled my valve cover about 3 times in the past several months trying to track down where a ticking noise is coming from. I think I have narrowed the tick down to the very back no.6 exhaust valve. I don't think it's normal to be able to hear this sort of ticking from inside the cab when applying the gas. I noticed this tick around 25,000 miles on the truck & right now it only has a little under 40,000.This last time that I pulled the valve cover I found the valve to be out of adjustment & so I tightened it up. Before I adjusted it I pulled up and down on the rocker I was kind of surprised but there seemed to be a small amount of movement between the rocker arm & the push rod???? I didn't really think that it should be possible though with the nut being tight....The tick seems to have quieted a little after I adjusted it but I'm still worried there may be something wrong. The tick can only be heard when applying the gas lightly when going up a grade or starting out from a stop.....seems to have to do with rpm & load on the engine....i don't hear anything unnusual when the truck is just idling.....Anybody experience a similar problem like this? Thanks.
