Ball Joints - Nightmare!
- Replies 28
- Views 8.4k
Mopar1973Man 9 posts
dripley 8 posts
Dave3500 3 posts
Perrysburg Dodgeboy 2 posts
Well gang... I started down the long rocky trail of doing ball joints on my truck. Took me over 12 hours to do just the passenger side. As for getting every broke down for removal was a snap. Now the hub nut on the spindle is 1 11/16 nut and had to drive to town and get the right socket. ($14) as for getting the wheel bearings out snap to with a partner there to help out. The socket extension trick does work but not as documented. My buddy James used a longer extension and allow it to push off different areas of the axle tube.Other than that no problem. Take a 8# sledge hammer and nail the top of the knuckle near the upper ball joint and off it came. Now as for using the Harbor Freight ball joint press tool. Well it works but you got to be creative with it. We started with the lower ball joint and with even using a cheater pipe on the ratchet we couldn't get it to move. So after calling a few local tire shops most suggested heating and beating with a sledge.
