- Replies 18
- Views 6.9k
48kenworth 6 posts
MnTom 2 posts
AH64ID 2 posts
mr.mindless 2 posts
I am finished beating my head against tthe wall chasing idle haze and high egt's!!!!!! To date I have replaced the lift pump, turbo, Had the injectors cleaned and popped, Had the injector pump gone through tested and reset, and put in a intercooler out of a 95 dodge. I still have high egt's and heavy idle haze and have decided that there are only two possible reasons for my problem. 1: my exaust valves are leaking and causing low combustion pressure/temp at idle and blowing heat made for the cumbustion chamber out the exhaust while driving. Or 2: I have some really cheap crappy aftermarket performance injectors and dont know it. I am leaning toward #1 so I turned the pump down a little more bumped the timing 1/4 inch and took all my aftermarket gauges out!!! I figure since I have replaced everything but the longblock at this point she will either run or blow at this point I dont much care anymore!!!! Ok I feel better!
