boost bolt
Hey everyone just want a few opinions. My brother just got a cummins so I might be selling my edge to him since I only use it for the gauges. With that said I am going to have to get a new pyro and boost gauge. I have a banks high ram intake horn but it is not tapped for a boost elbow. Should I tap that or does anyone know how well that boost bolt works?:shrug:
  • Replies 12
  • Views 5.1k
The boost volt works really well, I have been using 2 on my truck for the past year and have had no problems. Just remember to torque it to 18 ft.lbs.
Or you could do the easy way... There is a 3/4" pipe plug in the side of the maniold... post-2-138698179861_thumb.jpg
I have a threaded port on the outlet side of my turbo where my boost fooler and wastegate pressure line is connected and I just used a 'T' fitting to connect the line for my boost guage. Been that way for 5 years now. This setup seems different than some others are doing so I hope it isn't wrong to do it this way.
The boost bolt is the best and easiest way to go.
I don't think 3rd gen's have that plug in the side of the head.
It's not wrong, but will read a higher pressure than what the manifold/motor are seeing.
looks like I'll be trying the boost bolt it beats taking off the intake horn and tapping it anyways.
And on a 3rd gen provides much more accurate readings.
would it get a better reading as to which bolt you remove? Or doesnt it affect it at all
I am not sure it matters.
He's right it doesn't matter... But what does matter is the place where the tube is going to be. Is it going to be in a spot prone to be damage because of doing service to the engine? Like the boost bolt points the tube straight up right in the middle of all the high pressure lines. So every time you work on doing a valve adjustment etc. you take a risk of breaking the tube or damaging it. But if it located low on the head like where mine is highly unlikely to get damaged because of where its located. So the pressure will all be the same is just location might cause problem for damaging the tubing...
not trying to hijack anything, but how accurate is the map sensor compared to other setups yall are speaking of? my gauge is getting its reading from the amp sensor.
It doesn't seem to be quite as accurate as an analog gauge, but then again boost is derived from manifold pressure minus intake pressure, so it will almost always be higher than an analog gauge.
