Headlight Problems
A while ago I hit a deer,my Right headlight got busted. I replaced the light and bulb.The high beam light came on and wound not go off of,driving lights and high beams stay on at the same time.I have checked the fuse and they are all good the high beam light does not go off stays on .Does anyone know what the problem could be.I would appreciate it if some one could help me .thanks
  • Replies 10
  • Views 4.4k
sounds like either a short up front, or a possible failure in the turn signal switch assembly.
Check your wiring for insulation damage or pinched wires up around the headlight.-Jordan-
Sounds to me that you have power feeding the high beam and drive lights at the same time or the dip relay is stuck. In other words a hot (battery voltage) wire is feeding current to the lights. Trace the wire harness from the head lights and drive lights and see what they have in common,IE harness, relay, switches, ect, ect. Inspect the damaged area carefully. A test light, ohm meter, and wire diagram are helpful.
thanks[/quote
You have the wrong bulb,9007/9004 look the same but are not, you need the 9004.:2cents:
Bulbs 9007,and the wiring are good,no damage.
BlueOx caught you...:smart: 9007 is the wrong bulbs...
9004 bulbs are correct...
Posted Image
Posted Image
Nice job M73M!
Posted Image
Thought thats what I said he needs 9004 bulbs,did you miss read?:banghead:
Nice job M73M!
Thought I said 9004 was correct,went through this myself,:mad:
Blue, you did, and Mike quoted that you did.. :shrug:
thought saying he "caught me" ment I was suggesting 9007's:doh: my bad.
