- Replies 23
- Views 4.3k
Fullboarcummins 10 posts
JOHNFAK 4 posts
dripley 3 posts
DezrtRat 2 posts
So I have a cracked #53 block in my truck. I have found a number of sites that claim the crack can be repaired by stiching it. Sounds like a bad idea to me. What do you guys think about this? Maybe if the truck would never be modded. But I plan on making 500-600hp. Are 12 valve and 24 valve blocks compatible in any way? Would a motor out of a 02 work in my 99? Im just trying to save a few bucks. I have a complete 99 engine lined up for $1100. But it will need a rebuild costing me another $4000. I also found a complete engine out of a 02 with only 94,000 miles on it for $3200. I was told some engines have cam and crank sensors. While others only have a crank sensor. Can I save the cash and make the 02 engine work using parts from my current engine? Or should I spend the extra money and go with the same model year engine? I have alot more time than money for this project. Thanks in advance for any advice.
