- Replies 27
- Views 5.1k
Mopar1973Man 9 posts
99dgcummins 9 posts
JAG1 3 posts
CUMMINSDIESELPWR 3 posts
Ok guys my truck has me stumped! Ill start from the begining and tell everything... My truck was doing the TC Lock and unlock at 45 MPH, after reading some stuff online I tried wiggling the black and white wire going from the battery to the alternator, stopped that problem I would just have to wiggle it every 3 weeks or so. The WTSL wasnt coming on either. So one morning(Months Later)I was leaving and my truck would idle fine but when I put it in gear I would have to push the throttle down like half way to get it to go, the truck felt like it had no power, it went to 3000 RPMs before it would shift, and when it did shift it felt like it was going to die. I pulled over like 1/4 mile from the house and turned the truck off got out wiggled that black and white wire from the battery to the alternator it ran fine. Went back home let the truck sit and about 6-7 hours later started it up, took off, and it did it again. My check engine light came on, I put some de electrical grease in the plug on that wire and it stopped, it ran fine, CEL went off for about a week, and my WTSL came on for the first time in a year. I noticed that it does it almost every morning now so what I have to do is start the truck let it idle until it warms up turn it off get out unplug and plug in the plug in the wire going from the alternator to battery and it will run fine. Also the truck will not start until the WTSL comes on which is about 10 sec after I turn the key. Now that it is doing it again the CEL came back on so I took it to pep boys to have the codes read. The technician said that I have either a fuse blown or a short somewhere because the code reader wont pull the codes off the truck. Im stumped I dont have any idea what to do next!
