- Replies 16
- Views 5.2k
I6FREAK 8 posts
Mopar1973Man 6 posts
gassernomore 1 post
dripley 1 post
i changed the 15 psi spring out for the 17 psi spring and it worked great, then i went back and put the 15 psi spring back in and the regulator which is on pump snd there is no pressure but the pump does run when bumped. is there something under the ring that the spring sits on that i could have misaligned?
