- Replies 37
- Views 7.9k
CUMMINSDIESELPWR 11 posts
Rebelrodder 10 posts
Mopar1973Man 5 posts
dripley 5 posts
OK fellow Cummins fans, I've got a big problem that many days of web searching has not found an answer to.I recently replaced the VP$$ and added an Airdog 100. Now my truck will start fine when cold and runs great. The trouble comes when I try to start it when hot. The engine will fire immediately and idle for a couple of seconds then it stumbles and dies. I can re-fire it immediately with the same result. If I try to start it within 5 minutes of shutdown all is well. Beyond that it's a no go until the engine is cold again. Does this condition fall under the hot start banner? Would the LP cutoff relay mod help me? Idle PSI is about 17psi on my test gauge. I don't have an in cab gauge yet since i had to blow my gauge fund on repair parts.
I did plumb in a needle valve in prep for a gauge. :thumbup2:I have checked all points along the fuel lines where there is a connection and found everything to be tight. All high pressure lines are tight with no visible signs of leaks. I also checked the return fitting at the back of the head which did have a loose connection but did not solve the problem. I checked for codes and found none. I did not have this problem before the VP died.I'm at a loss here! Any thoughts? :banghead:
