Engine shuts down when the head lights are turned on
- Replies 14
- Views 16.9k
Oldcarmechanic 4 posts
pepsi71ocean 3 posts
2500ctd 2 posts
RAM2000Silver 1 post
I am working on my brothers 1999 Dodge doollie, 3500 extended cab with the 24 valve Cummins Turbo Diesel. When you turn the headlights on it kills the engine. The problem is sporadic and will come and go. I pull the ASD relay and the engine will run with the headlights on, after a while, maybe five minutes it will kill the engine, when you turn the headlights back on. I have replaced both the ASD and Fuel pump relays. I also have .5 amp discharge from the battery, which I tried to track down by pulling circuit fuses, one at a time. I did not find it. I believe I have a bad ground somewhere but can't find the link between killing the fuel pump (engine dies) and the headlights being turned on. Any help!
