- Replies 23
 - Views 4k
								98whitelightnin 12 posts
								ISX 4 posts
								JOHNFAK 2 posts
								dripley 2 posts
I replaced my water pump a few months ago and ever since I have had fluctuating temps. The new pump is a bosch from pepboys and had a shroud on the impeller and the old unit did not, I also noticed the new one was harder to turn than the old one but that is to be expected. My temp used to set right around 188-194 and now driving down the interstate at 70 I get swings from 188-222 today. It would go up pretty fast and come back down to around 200-205 or so but I cant help but theink its the new pump. I may try a new radiator cap too but what does everyone think?
The old pump worked great but I did a coolant flush and it leaked from the weep hole afterwards and is the reason it was replaced. The o-ring was also flat but I dont believe it leaked, if I were to put a new o-ring on it would it fix the leak from the weep hole? The bearing and impeller feel tight and spin freely.
