man, this thing is AWESOME, so many different parameters can be shown, i found out from it that my TPS needed to be reset, so, i did that....also, for w/e reason, at idle, the MAP thing shows like 30, i don't know if that's good or bad...:confused
anyway, here are some pics of where i mounted it and a couple vids of it in action...
Posted Image
LOVE that fuel mileage... :hyper :D
Posted Image
vids.....
Posted Image
Posted Image
gotta wait about a week till i get to around 1/4 of a tank so i can calibrate it all the way right....
  • Replies 16
  • Views 3.8k
Nice job 2500,Is that the same one you have Michael? So with this setup, one doesn't need the other gauges, fp, trans temp, etc. Right? So the Scan II functions as a diagnostic & monitoring device?I did check out Michael's youtube vid w/ fuel milage data, 23.1 MPG, trip distance, fuel used, etc.Cool toys for big boys, :thumbsup Dave
The only gauge I know of that doesn't respond properly is the MAP... It should start at 14.7 PSIA and go up to 54.7 but for some reason it starts at about 28-30 and goes to 37.7 then stops... Now the MAP shows true on 2003 and up Cummins... :thud
I have had my scan gauge a week and I like it, not sure how everything works, or what it is for, but I am learning. The MPG gauge is no fun, I see the mpg and I take my foot off the go pedal :D
My overhead MPG is instant & right on in my pure stock truck... the mpg function is worthless. The average mpg is usefull. If I really want to get good average mpgs I keep the rpms below 2000 as much as possible. Shut off the cruise. Run it with my right foot, Never feed fuel to the truck if it will coast the desired speed, back off gradually as I crest hills. It's worth about 0.5 mpg. I've been able to coax this 4:10 truck to 18.6 on seasonable trips. If time is more important, I can drive more agressively & kiss that last mpg good bye.Russ
I have an early model Scangauge and love it. May upgrade to the newer one but frankly for the price (it was free) its hard to beat.
Hey,Has anyone checked the horsepower rating with dyno????? Just wondering how accurate it is!!!Thanks,Winslow
Well it would be rather difficult being that ScanGauge II is calculated flywheel horsepower and Dyno is rear wheel horsepower... There is several factors that vary the results... * Dual rear wheels Vs. Single rear wheels * Oversized tire or Unsized Tires * Tranission differences (Auto, 5 speed, 6 speed) * gear trian differences (3.55 / 4.10) On and on... But here is my results... http://mopar.mopar1973man.com/personal/ ... o/dyno.htm Now I've pulled as high is 423 HP (flywheel) on the scangauge... :wow Maybe that why my stock clutch was slipping (rated for 400 HP @ flywheel) :confused:
Hi Guys,OK you cats sold me. Think I'll have santa bring me one. Any better price on these othe than AutoZone for $169?With my luck though, it may say replace the truck or replce the loose screw behind the steering wheel! LOL Does it give FP, trans temp, boost, etc. readings?Thanks,Dave
Hi Guys, OK you cats sold me. Think I'll have santa bring me one. Any better price on these othe than AutoZone for $169? With my luck though, it may say replace the truck or replce the loose screw behind the steering wheel! LOL Does it give FP, trans temp, boost, etc. readings? Thanks, Dave
It can only see what the ECM/PCM monitor... As for boost reading on the 98.5 to 2002 is incorrect and doesn't display properly... But the 03 and up model year Cummins show correcly... The voltage offset in our MAP sensors fouls the reading... But all other sensors work fine... (IAT Temp, Coolant temp, flow rate of fuel (GPH), Engine load, MPG, APPS sensor, MPH, RPM's, Voltage)
Michael,What's the install like, just plug it into the OBD right? All the things you've mentioned are all then monitored?Thanks,Dave
Michael, What's the install like, just plug it into the OBD right? All the things you've mentioned are all then monitored? Thanks, Dave
Very long and detailed installation! Plug it in the OBDII port and drive! Setting the unit up the way YOU want it takes 10x the time but well worth it.
http://www.cumminsforum.com/forum/diese ... ipped.html
Great posts guys, wonderful info, just what I really wanted to check out!Thanks everyone,Dave
