I am in the process of making my own intake horn. I'm too cheap to buy one, and I have the materials, the time, and the equipment to do it. I will also temporarily eliminate the grid heater until September or October. The intake tube will be 3" OD, made from driveshaft tubing from a 1985 Dodge 3/4 ton truck. The first pic is the flange that bolts directly to the intake manifold. The center hole in the flange is to make it easier for me to torch out the 3" circle......it gives me an easy starting point.
