- Replies 9
- Views 1.7k
Mopar1973Man 2 posts
volkswagon 2 posts
JOHNFAK 1 post
kennyv 1 post
For a while now, I have been debating if I should put a TC switch in. I know of the benefits I could get from it, but what about the negative?I want to do the switch because I want to maximize the fuel milage by reducing the fluid coupling of the automatic, and reducing heat.Anyone done it and what to do and not to do with it? At that rpm do you shut it off at? Also, could this be a good way to substitute for being able to use an exhaust brake?
