Raptor FRRP and 1/2" line
- Replies 19
- Views 5.1k
jonathan1950 7 posts
Mopar1973Man 2 posts
dripley 2 posts
anoldbiker 2 posts
I have all the parts and pieces to install my Raptor and 1/2" fuel line. I will post some pictures as I go along. I am using the stock fuel filter but am also installing a remote fuel filter(Carquest 86353) and water seperator(86439). I have a short box so room is limited under the truck and I am looking at installing the filters and then the fuel pump. Other than when I change filters, possible having air in the system and having to bleed it out, does anyone know of any problem with doing it this way? I can put the fuel pump first, but it will take a little more engineering. Also one advantage I can see is that the fuel will be filtered before the pump, which may help keep the pump going for a longer time.
